Posted
why is the modern trend to use O ring chains instead of split link, split link chains are a darn sight easier to get on and off
Posted
I'm the last person qualified to answer mechanical queries, but my understanding is safety.
It's years since I had a split link in a chain......and I'd be very apprehensive if I had one now!
Posted
 Ive had one on my KLR for almost 20k miles, and its an o ring too. ?
Posted
got to say that i think all my bikes have had a split link and never had a problem, still think O rings are a modern trend
Posted
The outside still nedds lubrication, i did have a stick knock the master links link off once, wouldnt have been pretty if i didnt notice.
Next chain on will be rivited God willing.
:wave:
Posted
O Rings are far superior.....the grease is packed in them. They last so much longer than the old chains we used to have.
But like Tym says they still need checking and lubing.
Posted
its ok if you have a chain splitter
Posted
O ring chains might sap some hp, not sure if it matters or not anymore. ?
Posted
Used split link o ring chains on my off road bikes just for ease of swap and cleaning.
They do but x ring helps on the score.
Posted
Real bikes use belts.
Posted
13 minutes ago, Catteeclan said:
Yeap.
i bet the owner fed all that raw power in gently trying not to snap that belt :classic_biggrin:
Posted
Blimey Lionel are you still in 1979 ?  I have x-ring (superior to o-ring) chains on my bike but they still have a split link to join them.
Posted
Poor old Ren's still in 1972!
It's like a fucking episode of "Life on Mars" in here"
Posted
I think you are mistaking O ring with rivet link, You can have a standard, O ring or X ring chain with a split link or rivet link. A small angle grinder removes any chain easily and two hammers will rivet a link together easily
Posted
1 hour ago, Pedro said:
Soaking your chain in boiling atf, that’s the latest tech ...
You are supposed to use the body fat of plump virgins.
Posted
thats what i do with the serow chain ?
Posted
now that sounds better (no having to cut your chain off with bolt cutters)
Posted
what do you reckon to that audi quatro (or is that the one after life on mars)
Posted
That was Ashes to Ashes!
You seen this?
Posted
Not many of them to be found in these parts.
Life on Mars and Ashes to Ashes, great tele.
Posted
Best programme since The Prisoner I'd say Dave!
LOM was better.....I thought ATA went on a bit too long and they were struggling for stories a bit.
But the ending saved it......that was mind blowing!
Posted
I'd agree there but Keeley was better to look at.
Have you tried Line of Duty? Haven't watched this last series yet but the previous has been good.
