Posted
4 minutes ago, Slowlycatchymonkey said:
I haven’t got this bit
I may have been short changed out of a quality lead!
That came with it, its just a USB charging lead
Posted
Its much meatier look version that what I have.
It's just  got a ferrite bead on it to stop unintentional electrical interference
Posted
You can see from the size of the bead its on a chunky wire. No matter less for me to carry!
Posted
On 20/03/2023 at 15:46, Slowlycatchymonkey said:
Well there's a good endorsement. Thanks Bob.
Over here the 45 is slightly cheaper and as they're roughly the same size I went for that one.
As it will be sitting uncharged for sometime I figure it can afford to lose more charge than a smaller unit.
It may also have to do two bikes potentially more than once.
The phone charger element is a big pus. Being a bit stuck was one thing but a dying phone leaves you unable to sort anything out. Contingency plans when you have no connectivity and can't use google translate aren't the most fun 😂
i got one of them ...brilliant bit of kit
Posted
25 minutes ago, Six30 said:
i got one of them ...brilliant bit of kit especially for all the cars I sell with fucked batteries because I have them for so long trying to shift them they all go dead
Yeah we know you're type.....
Posted
On 22/03/2023 at 22:29, Slowlycatchymonkey said:
See the thin thing on the table  image.jpeg.c3344fe29acbc949dd0d199fc3d6c7d0.jpeg
As a forum moderator it is my duty to inform you that it's bad etiquette to be taking photos with your pyjamas on.
Please do not do this again ..................
Yellow Card GIF by bett1
Posted
Take that yellow card back, it’s a sundress!
Posted
2 hours ago, boboneleg said:
Bang on Fred, I'm going to get me on of those 👍
Me to , Fred does have some uses 😄
Posted
Mr Slowly said I don’t think those clips will fit on your battery.
Cors they will I replied confidently.
Later I think hmm best check if I need to carry other tools to get to it.
The positive is a bit of a squeeze but I can fit them on - just!
Probably should cut that cable tie but for some unfathomable reason the sleep deprivation helped me decide not to 😆
Posted
Bloody dirty there! Mine is spotless!
Posted
Will you stop it my neck don't work sideways
good job they made the battery terminals accessible Not
Posted
Yep they definitely didn’t pay it due regard.
Getting the bastid thing out is a right royal pita. One of the frames bars cuts across the corner of the battery housing. It has to be levered from behind and pulled from the front in a wriggling motion. Total fail.
Yes Pete I should have got a Honda 😜
Posted
Just put a strap round the battery next time it is out, then you can use that to lift the battery out next time.
Posted
13 minutes ago, Buckster said:
Just putva strap round the battery next time it is out, then you can use that to lift the battery out next time.
Good idea, I will but have you seen how much crap (including part of the bike frame) they have running over the side of the battery? It’s ridiculous.041E914E-497A-42B2-8F69-967B6CB77B1A.thumb.jpeg.0ff7aaa164b202def5b0079736169c92.jpeg
