1998 Triumph Sprint Project.
Saul
1 hour ago, Saul said:
Been having a Triumph group chat and the consensus is that the Clutch slave needs a rebuild and that should hopefully fix the clutch probs.  Looking like at least carb clean and balance is on the horizon so I may well be bending your ear @Clive.  Going to order some new rubbers before even attempting to get them off though.
Yeh new intake rubbers were one of the 1st things I bought for the Tiger, the original ones were badly cracked and had gone very hard.
My problems stemmed from the bike being stood for years, the middle carb was corroded very badly (but Bruce gave me a spare set) so the middle carb was replaced.
I may have got it running sooner and better if I had a ultrasonic cleaner, carb cleaner and toothbrush were not the best for cleaning out the internal passage ways.
Even with the Carbtune Pro that Bruce gave me, balancing the carbs was a fiddle, it took me more than several attempts to get it right.
Make sure he tells you how to flounce after the third attempt.
How did you get on with the bike once you sorted it.
It was fabulous, a heavy beast, but once on the move most of the weight seemed to disappear, very comfy too, but too heavy a bike for a old man like me. Lol
34 minutes ago, Clive said:
It was fabulous, a heavy beast, but once on the move most of the weight seemed to disappear, very comfy too, but too heavy a bike for an old man like me. Lol
  I know have only done 40 miles on the Sprint, but it was a blast,  Bike comfy and fast enough, I really liked it.   It feels like the big old 1980’s bike that I can’t afford.    I know when these T300’s were current they weren’t real dynamic competition for the Japs of the day but now they fit in a whole different niche.   I can’t wait to get it right and pile on the miles.
Small step to help fix the Sprint.   Reference the slipping clutch I was told to rebuild the clutch slave cylinder as if it had been neglected it will stick.    Known issue with the T300.  I stripped it and was pretty disappointed to see it had spotless fluid and was clean.    Bugger probably not that then.  🙁.
Anyway I had the kit so fitted the new seal and spring and bled it all up with fresh fluid.   Appears to be working well but not much hope of it fixing the clutch slip.   But we shall see 🙄.
IMG_6504.thumb.jpeg.6206a582228e054b47d48d7c4b8f27e0.jpegIMG_6505.thumb.jpeg.54b19992d64df67f52403ec0fecacfbc.jpeg
As soon as I get the chance the next job is to get the carbs off and sort the tickover out.     I’m not sure I need to strip and clean them as the bike is starting fine and running well, it’s just when I went to adjust the tick over knob it detached off the adjustment screw which you just can’t reach with the carbs in situ.  So they have got to come off just to put that back together.    Absolute pain in the arse.   As it was ticking over fine but I messed with it.   😢.  I sort of hoping the carbs  are fine as everything else on the bike seems to be well looked after but we shall see.
I have a new set of carb rubbers so I will dig into it as soon as I get chance. IMG_6506.thumb.jpeg.8691eecb4cd01abebc536817dfbbc7e9.jpegIMG_6507.thumb.jpeg.ed4e3d3faa6fc175af86193519c88f4a.jpeg
  • Like 6
15 minutes ago, Catteeclan said:
Keep up the good work Saul. Always learning along the way.
Absolutely, that’s the fun part.   😉
Just been out for a ride and the clutch slip has gone.   Rebuilding the slave cylinder cured it 😎
Still got the tick over to sort out, kept it going today by just keeping the choke slightly cracked.    Not ideal but good enough to check the clutch out.     Oh and heated grips are a necessity came back shivering like a shit house rat today.   😳
  • Like 6
5 hours ago, Skippy said:
Looks like you’ve done a cracking job there Saul, these things all take time eh?
They do mate but that is part of the fun.  😎
  • 2 weeks later...
Here we go let the tears and swear words commence.   Time to get the carbs off 😳😳😳
Flounce alert!
Well the carbs came off without to much drama.  Throttle cable was a bit of a pig but ok in the end.     Initially took the float bowls off and there was some sludge so have cleaned them all out.    Gonna re watch some carb cleaning vids before going any deeper.
On a side note the carb rubbers are not old at all.   Both airbox and motor sets. All pliable and in great condition.   I’m fairly sure that have been replaced at some point.    Also the air filter looks in very good condition and must have been replaced recently in mileage terms.   Good to find out but sort of wish I didn’t have a new one sitting on the bench, that is a few quid I could have saved as are the new set of rubbers.  I intend to keep the bike so they will be used at some point.
eeeesh, yep that's pretty grotty.  Well worth doing 👍
Yeah bit dirtier than I expected to be honest, they bike seemed to run pretty well.  The tickover issue developed after I messed with it but before it was fine.  But now I am in might as well do everything, I have a full rebuild kit including floats and jets so seems silly not to do it properly now.
Here we go 😳
Good luck. I always find I have a few bits left over once I put stuff like that back together 😫
