Catteeclan Posted April 16 Posted April 16 Right so got some time to play. Rear wheel moved forward to get the chain off the front sprocket, 30mm socket on the drill. No noises picked up using the screwdriver to ear method. Think this next pic gives a better clue to the prob. Glad I couldn't hear anything from the transmission as it would have been a right ball ache to sort. Rear sprocket not so bad but think another set is in order. I've been using a tin of muck off all weather chain lube, no probs with Mandis or the dominator but this is the second set on this done at 13000 miles. 3
Catteeclan Posted April 16 Author Posted April 16 I realise this is all alien to you and your Beemer Pedro, have you still got the XR?
Pedro Posted April 16 Posted April 16 9 minutes ago, Catteeclan said: I realise this is all alien to you and your Beemer Pedro, have you still got the XR? I do, haven’t ridden it in ages. It’s got a clogged carb as well, which I will have to sort before it moves. Does look nice as a garage decorative piece, though … 2
YamaHead Posted April 16 Posted April 16 5 hours ago, Catteeclan said: Think this next pic gives a better clue to the prob. Yeah, it looks like a couple of those teeth are looking kinda pointy....not much crown left on them. Like you said, at least it's not the gearbox....chain & sprockets are a piece of cake. 2
boboneleg Posted April 17 Posted April 17 11 hours ago, YamaHead said: Yeah, it looks like a couple of those teeth are looking kinda pointy....not much crown left on them. Like you said, at least it's not the gearbox....chain & sprockets are a piece of cake. Also looks like the chain has started to grind into the boss of the sprocket 2
Catteeclan Posted April 18 Author Posted April 18 21 hours ago, Buckster said: That front sprocket is goosed. Is that the same as knackered? I normally keep a record of when I changes parts but for some reason didn't bother. Bet that set had done less than 10,000. Was a DID chain and JT sprockets. Watching a couple of genuine sets on eBay at the mo.
