Buckster Posted 3 hours ago Share Posted 3 hours ago Did you put a 7.5 amp fuse in the junction box? Link to comment Share on other sites More sharing options...
Saul Posted 2 hours ago Author Share Posted 2 hours ago 14 minutes ago, Buckster said: Did you put a 7.5 amp fuse in the junction box? The box has 4 x 5am fused circuits. Link to comment Share on other sites More sharing options...
Buckster Posted 2 hours ago Share Posted 2 hours ago 14 minutes ago, Saul said: The box has 4 x 5am fused circuits. I know but users usually upgrade the fuse for heated grips to 7.5 amps as the 5 amp is prone to blowing. 1 Link to comment Share on other sites More sharing options...
Saul Posted 2 hours ago Author Share Posted 2 hours ago 3 minutes ago, Buckster said: I know but users usually upgrade the fuse for heated grips to 7.5 amps as the 5 amp is prone to blowing. Haven’t encountered that yet, the commuter grips draw 3.2 amp max so less than the 4amp ones I had on the CBF before which is set up exactly the same way. Mind you I practically never ran the grips on max, normally setting one or two out of five. Wouldn’t hurt to pop a 7.5 amp fuse in I suppose especially as the box won’t be that easy to access where it is. Can be accessed from below but a fiddly bastard of a job on the roadside. Link to comment Share on other sites More sharing options...
Buckster Posted 1 hour ago Share Posted 1 hour ago 19 minutes ago, Saul said: Haven’t encountered that yet, the commuter grips draw 3.2 amp max so less than the 4amp ones I had on the CBF before which is set up exactly the same way. Mind you I practically never ran the grips on max, normally setting one or two out of five. Wouldn’t hurt to pop a 7.5 amp fuse in I suppose especially as the box won’t be that easy to access where it is. Can be accessed from below but a fiddly bastard of a job on the roadside. The grips will have an inline 5 amp won’t they? Link to comment Share on other sites More sharing options...
Saul Posted 1 hour ago Author Share Posted 1 hour ago Yes Link to comment Share on other sites More sharing options...
Buckster Posted 1 hour ago Share Posted 1 hour ago 27 minutes ago, Saul said: Yes I would fit a 7.5 amp to that outlet to make up for the additional load from the cable. Link to comment Share on other sites More sharing options...
