Hugh Janus Posted October 4, 2023 Posted October 4, 2023 Ducati fitted the DesertX Rally with serious off-road equipment. (Ducati/)Ducati’s DesertX marked the return to the no-holds-barred kingdom of hard off-road riding, from the almost forgotten days of the 450 R/T that was urgently developed to equip the Italian team to the 1971 ISDT at the Isle of Man. The DesertX proved to be developed down to every detail, very capable, and with strong potential thanks to the gloriously versatile 937 11° desmo Testastretta V-twin. Now Ducati has branched out to give life to an even more specialized version, the DesertX Rally.To test its ultimate potential against the toughest off-road riding conditions, the DesertX Rally debuted in a prototype form at the Iron Road Prolog of the Erzbergrodeo 2023 in the hands of multiple Enduro World and European supercross champion Antoine Méo who took it to the win in the twin-cylinder class.Development of the DesertX Rally was totally devoted to the adoption and optimization of racing-derived technical components in order to fully extract the potential of an already rather strong combination of a very capable chassis and potent 937cc eight-valve desmo 90-degree V-twin.The steel-tube trellis frame has been retained in its original form, both structural and geometrical, with the steering rake set at 27.6 degrees to generate 4.8 inches of trail in combination with the 21-inch front wheel. The only differences are consequent to the Rally’s adoption of long-travel race-derived suspension.Long-travel suspension ups the DesertX Rally’s off-road game. (Ducati/)Billet aluminum triple clamps carry a 48mm Kayaba cartridge fork featuring special treatment of the inside of the stanchions (Kashima coating) and at the sliders (DLC treatment) to grant maximum smoothness under the toughest riding conditions. The new fork is 30mm longer and ensures a front wheel travel of 9.8 inches, 0.8 inch more than the standard unit. That longer fork also causes the wheelbase to stretch from 63 to 64 inches. Kayaba also supplies the new rear monoshock unit. In addition providing a rear wheel travel of 9.4 inches, the new unit features a larger 46mm piston for a more efficient damping control needed for severe off-road duty. The new rear shock is also fully adjustable in compression and rebound with a remote preload adjustment. An adjustable Öhlins steering damper is standard equipment as well.Behind that Öhlins adjustable steering damper are billet triple clamps holding 48mm KYB fork legs. (Ducati/)The seat height has gone up from 34.4 to 35.8 inches, but a lower seat (34.8 inches) is available as an accessory. A meaningful modification of the chassis setting comes in the wheel department with a traditional carbon steel spoke arrangement on Takasago Excel rims and billet hubs—consequently demanding that the tires be fitted with tubes. DesertX Rally is available with a selection of three tires; Pirelli Scorpion Rally STR is the base tire, but for extreme off-road performance the alternative is the Scorpion Rally. Those who want to spend more time on macadam than on dirt have the Pirelli Scorpion Trail II as the optimal choice. They all come in 90/90-21 and 150/70-18 sizing, front and rear respectively.Special graphics on solid-color plastics are meant to take a beating better than painted surfaces. (Ducati/)The braking department looks adequate for a sportbike, with the front disc brake consisting of two 320mm rotors and radial mount, four-piston Brembo Monoblock calipers. At the rear, a 265mm rotor is teamed to a two-piston caliper. The whole system is managed by Bosch cornering ABS.Kashima and DLC coated surfaces increase the smoothness and function of the DesertX Rally’s KYB fork. (Ducati/)As mentioned above, the engine remains the highly capable 937cc 11° Testastretta eight-valve desmo 90-degree V-twin. This unit is one of the more flexible, smooth, and responsive in its class. In addition, the 937cc version of the Testastretta was the first to switch from a hybrid crank assembly layout (with con-rods turning on plain bearings and the crankshaft turning on old and faithful aero angular contact ball bearings) to a full plain bearings design that offers quiet operation and superior rigidity. The powerplant produces a standard 110 hp at 9,250 rpm, same as the base-model DesertX, and delivers 68 lb.-ft. of peak torque at 6,500 rpm. That’s an outstanding interval of almost 3,000 rpm separating peak torque from peak power—a condition that grants excellent engine response over a very wide rev range.Ducati claims 110 hp from the DesertX Rally’s 937cc 11° Testastretta V-twin. (Ducati/)To assist the rider negotiating the hardest terrain, the DesertX Rally features a very comprehensive electronics suite. The ECU offers six riding modes (Sport, Touring, Urban, Wet, Enduro, and Rally) in addition to cornering ABS and traction control. An electronically controlled Ducati Quick Shift (up and down) and wheelie control are also standard equipment. A 5-inch TFT instrumentation display acts as the control center of the electronics suite. It is designed for integration with Ducati Media System so that the rider can connect their smartphone to access more information and Ducati’s turn-by-turn navigation system.Special-edition graphics on solid-colored plastic bodywork—painted parts show scratches too easily—along with a single-piece rally seat and carbon fiber skid plate are the finishing touches on the DesertX Rally.Price in the US will start at an MSRP of $22,995. Better get to your local Ducati dealer quick!Ducati’s DesertX Rally has an MSRP of $22,995. (Ducati/)2024 Ducati DesertX Rally Specs MSRP: $22,995 Engine: Testastretta 11° desmodromic, liquid-cooled V-twin; 4 valves/cyl. Displacement: 937cc Bore x Stroke: 94.0 x 67.5mm Compression Ratio: 13.3:1 Transmission/Final Drive: 6-speed/chain Claimed Horsepower: 110 hp @ 9,250 rpm Claimed Torque: 68 lb.-ft. @ 6,500 rpm Fuel System: Bosch electronic fuel injection w/ 53mm throttle bodies, ride-by-wire Clutch: Wet, multiplate slipper and self-servo; hydraulic actuation Frame: Tubular steel trellis Front Suspension: KYB 48mm upside-down fork, fully adjustable; 9.8 in. travel Rear Suspension: KYB monoshock, fully adjustable, remote preload adjustable; 9.4 in. travel Front Brake: Radial-mount Brembo Monoblock 4-piston caliper, dual 320mm semi-floating discs w/ Bosch Cornering ABS Rear Brake: Brembo floating 2-piston caliper, 265mm disc w/ Bosch Cornering ABS Wheels, Front/Rear: Spoked; 21 x 2.15 in. / 18 x 4.0 in. Tires, Front/Rear: Pirelli Scorpion Rally STR; 90/90-21 / 150/70R-18 Rake/Trail: 27.6°/4.8 in. Wheelbase: 64.0 in. Ground Clearance: 11.0 in. Seat Height: 35.8 in. Fuel Capacity: 5.5 gal. Claimed Curb Weight: NA Contact: ducati.com Source
boboneleg Posted October 4, 2023 Posted October 4, 2023 I wish I was younger and fitter so I could give that a go . The only downside to it that I see is the price . 1
Six30 Posted October 4, 2023 Posted October 4, 2023 The price of Ducati Desert Sled 2024 will be GBP11,996 in United Kingdom expectedly, all specs, features and Price on this page are unofficial, official price, and specs will be update on official announcement
boboneleg Posted October 4, 2023 Posted October 4, 2023 1 hour ago, Six30 said: The price of Ducati Desert Sled 2024 will be GBP11,996 in United Kingdom expectedly, all specs, features and Price on this page are unofficial, official price, and specs will be update on official announcement Have you got a source for that , as far as I know the Desert Sled has been dropped from the Scrambler range
Six30 Posted October 4, 2023 Posted October 4, 2023 45 minutes ago, boboneleg said: Have you got a source for that , as far as I know the Desert Sled has been dropped from the Scrambler range It was at this point I knew I’d fucked up … I just googled then copied and pasted.. but I didn’t put sled rally , the rally is said to be £18000 uk price 2
boboneleg Posted October 4, 2023 Posted October 4, 2023 It's a really good looking bike but I don't think I could shell out that sort of money and end up dropping it in some mud puddle 2
Six30 Posted October 4, 2023 Posted October 4, 2023 14 minutes ago, boboneleg said: It's a really good looking bike but I don't think I could shell out that sort of money and end up dropping it in some mud puddle Yup … I wouldn’t go no where near a mud puddle but couldn’t shell out 18k for a bike. and it probably wouldn’t go in the van 3
Pedro Posted October 4, 2023 Posted October 4, 2023 2 hours ago, Six30 said: Yup … I wouldn’t go no where near a mud puddle but couldn’t shell out 18k for a bike. and it probably wouldn’t go in the van Get a tall van 1
Pedro Posted October 4, 2023 Posted October 4, 2023 I do like the look of these bikes in pictures, in person they look like you´re wearing an expensive suit and expected to draw attention. I don't know how happy I would be owning a Ducati and more so how happy my mechanic would be if I was to own a Ducati. @boboneleg, how do you think these cope with miles? 1
boboneleg Posted October 5, 2023 Posted October 5, 2023 I’ll say this . The Desert X uses the 959 engine which is a derivative of the 821 . We’ve had two Monsters in with that engine that were very noisy. When we took them apart they both had massive play on the crank, we discovered that the crank doesn’t have a main bearing just a big bush. This smacks of cost cutting by Audi since they took control. My boss said if he had one he would junk the engine and fit an air cooled 803 engine from a Scrambler. 1
Pedro Posted October 5, 2023 Posted October 5, 2023 35 minutes ago, boboneleg said: I’ll say this . The Desert X uses the 959 engine which is a derivative of the 821 . We’ve had two Monsters in with that engine that were very noisy. When we took them apart they both had massive play on the crank, we discovered that the crank doesn’t have a main bearing just a big bush. This smacks of cost cutting by Audi since they took control. My boss said if he had one he would junk the engine and fit an air cooled 803 engine from a Scrambler. That’s not what one wants to hear before buying a premium bike. 2
Buckster Posted October 6, 2023 Posted October 6, 2023 21 hours ago, boboneleg said: I’ll say this . The Desert X uses the 959 engine which is a derivative of the 821 . We’ve had two Monsters in with that engine that were very noisy. When we took them apart they both had massive play on the crank, we discovered that the crank doesn’t have a main bearing just a big bush. This smacks of cost cutting by Audi since they took control. My boss said if he had one he would junk the engine and fit an air cooled 803 engine from a Scrambler. Who doesn’t like a big bush? 2
