Catteeclan Posted 1 hour ago Share Posted 1 hour ago Off again at last. Found plenty of shite in the float bowl. Needle valve looks fine, rubber still soft so fuck knows what's going on in there. The seat for the valve is tight and holds a vacuum with the valve in place and pressure come to that if I hold a finger over the hole. I'm going to reassemble with another new ethanol comp vale and see what happens. I may well cry a little if it doesn't cure the overflow and then burn the basted thing. Link to comment Share on other sites More sharing options...
