Posted
Yamaha Motor Europe announced updates to the Ténéré 700, giving the middleweight ADV bike a TFT display, smartphone connectivity, a new ABS mode and other small updates. As of this writing, the 2023 Ténéré 700 has not been announced for the U.S., though we expect to receive official news soon. The Ténéré 700 Rally Edition variant offered in Europe (pictured below with the Heritage White livery) also received the same updates, but we don’t expect that it will be offered on these shores.
110222-2023-yamaha-tenere-700-rally-edit
The most noticeable visual change for the 2023 Ténéré 700 is the new five-inch TFT display. The new color dashboard replaces the previous model’s LCD display, but it retains the rally-influenced vertical orientation instead of going horizontal like on most other motorcycles.
110222-2023-yamaha-tenere-700-XTZ700_EU_
The new display offers two modes, “Explorer” and “Street”. In Explorer mode, the display shows a linear digital tachometer to help riders maintain an optimal torque output for off-road riding. In Street mode, the display shows analog-style circular dials.
The Ténéré 700 is equipped with what Yamaha calls a Communication Control Unit (CCU) that allows the motorcycle to connect with smartphones via Bluetooth with Yamaha’s MyRide app. Once connected, the TFT screen can display incoming calls and messages, while the phone can show the bike’s data such as route tracking, distance covered, acceleration, top speed, elevation changes, and more. The app can also notify riders of any technical problems detected, and even email dealers to schedule service.
While the 2022 model only let riders choose to turn on or off ABS, the 2023 model offers three ABS modes: both wheels on, both wheels off, or ABS only to the front wheel.
Other changes include a more durable front brake lever design, a new USB charging socket, and LED turn signals. The 2023 Ténéré 700 also comes pre-wired for a quickshifter, though you would still need to purchase one separately from Yamaha’s accessory catalog.
Beyond these updates, the 2023 model is similar to the 2022 version. The 2023 Ténéré 700 will be available in Icon Blue and Tech Kamo. The 2023 Ténéré 700 Rally Edition will come in Heritage White, and includes an Akrapovič  exhaust, a radiator protector, a strong skid plate, off-road hand grips, grip pads, and a taller seat designed for easier transitions between standing and sitting positions.
2023 Yamaha Ténéré 700 Specifications (European Markets)
Engine Type 4-stroke, 2-cylinder, Liquid-cooled, DOHC, EURO5
Displacement 689cc
Bore x Stroke 80.0 x 68.6 mm
Compression Ratio 11.5 : 1
Horsepower 72.4 hp at 8,750 rpm (claimed)
Torque 49.4 lb-ft. at 6,500 rpm (claimed)
Lubrication System Wet sump
Clutch Wet, Multiple Disc
Ignition TCI
Starter Electric
Transmission Constant Mesh, 6-speed
Final Transmission Chain
Fuel Consumption 54.7 mpg (claimed)
Fuel system Electronic Fuel Injection
Frame Double cradle, Steel tube backbone
Caster angle 27°
Trail 4.1 inches
Front Suspension Upside-down telescopic fork; 8.3 inches of travel
Rear Suspension Link suspension, swingarm; 7.9 inches of travel
Front Brake Hydraulic dual disc, Ø 282 mm
Rear Brake Hydraulic single disc, Ø 245mm
Front Tire 90/90 – 21 M/C 54V
Rear Tire 150/70 R 18 M/C 70V
Length 93.3 inches
Width 35.6 inches
Height 57.3 inches
Seat Height 34.4 inches
Wheelbase 1.595 mm
Ground Clearance 9.4 inches
Wet Weight 449.7 pounds (claimed)
Fuel tank capacity 4.2 gallons
Oil tank capacity 0.7 gallons
110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-XTZ700_EU_ 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit 110222-2023-yamaha-tenere-700-rally-edit
The post 2023 Yamaha Ténéré 700 First Look appeared first on Motorcycle.com.
Posted
Big improvement, I feel sorry for anyone that has the older model.
Posted
Posted
Hooked one but damn if it isn't missing a fin!
Posted
That'll be an Eel then
